So I'm thinking about making a wood case similar to the S3/S4/Custom Mod 2.99L slim.
I don't have any components at the moment though, so I was hoping for some help with a few measurements so I can make the case as thin as possible.
The measurements I still don't know for sure:
-The MININUM space needed between the bottom case panel and the motherboard. Presumably this would be the thickness of cooler mounting plates/screws or a rear mounted m.2 + a mm or two. Since it's probably relevant, I'm considering the Zalman CNPS2X, Noctua NH-L9I/A, and the Silverstone AR05. Possibly the AMD Wraith Stealth or Spire (with a slimmer fan attached). If anyone knows the height of the stealth (doubtful until closer to the 11th), the height of the spire heatsink, or the thickness of the AM4 back mounting plate when installed that would be awesome.
-The height of the cpu socket and cpu. Is it different for am4 vs 1151? I found a picture with an image search saying 3.7mm for the cpu, and 4.2-4.4mm for the cpu socket, but I don't know how accurate those measurements are, if they are valid for current gen components, or if the AMD and intel parts differ in height.
-Height of tallest back I/O component. Basically, if I went with the 27mm tall zalman cooler and custom made a back i/o panel, what part is the tallest, the zalman or the i/o components?
Any help would be very much appreciated!
