HDPLEX HiFi 250W DC-ATX (nanoATX Series)
Power Supply HDPLEX HiFi 250W DC-ATX (nanoATX Series) 1.1
QinX
kees
Mar 2, 2015
541
374
QinX submitted a new resource:
HDPLEX HiFi 250W DC-ATX (nanoATX Series) - a high-end 16V to 24V DC input board for motherboards
This is a model of the HDPLEX HiFi 250W DC-ATX (nanoATX Series). all components have be either measured with digital calipers, capacitors, inductors and chips. or imported, molex Mini-Fit Jr. connectors.
The chips that are underneath the heatsink are also modeled.
The board is designed for a 250W passive load, but can go up to 400W with adequate airflow over the heatsink. In theory with this model a waterblock could be modeled for it.
4,783
You wouldn't happen to have a model of the 160W version would you?
QinX
kees
Mar 2, 2015
541
374
I don't have one, but looking at the images it shouldn't be terribly hard to make it if you'd like me to.
GuilleAcoustic
Chief Procrastination Officer
LOSIAS
Jun 29, 2015
2,984
4,421
guilleacoustic.wordpress.com
Does someone have the exact size of the HDPLEX 250W heatsink ? I'd like to know if any of those MOSFET copper heatsink would fit : Enzotechnology
What is the real surface that needs to be covered (whole length of the original heatsink or smaller) ?
Note: I have no access to CAD tool at hospital. I guesstimate it to around 100x10, but precise size would help me plan my design.
Reactions: Soul_Est
Soul_Est
1,536
1,928
Having looked at the page, I'd say that the MOS-C10 and MOS-C10-LE will fit but are a little on the small side at 10mm (L) x 10mm (W). Having looked over that gallery for the HDPLEX 250W, I believe you can use either the BMR-C1 or BMR-C1-LE at 14mm (L) x 14mm (W).
DASBOOT
288
236
Pointless models now, as all are discontinued for HDplex GaN, nothing else will be produced; to date.
