Resource icon
Power Supply HDPlex 250w GAN 2022-08-04
robbee
890
1,408
So I've recieved mine! Haven't been able to test it yet, but here are some observations:
- There is an extra, very short (7cm) 24pin cable in the box which is not listed on the site as accessory, which will be very welcome addition in cases like the S4 mini and S4 tiny
- The lenght of the CPU power cable is a bit excesive, but it as as listed on the website
- This thing is heavy for its size and feel solid like a truck
- You'll need to add an extra 3mm to the length on the ATX side for the 24pin retention clip
- The C6 inlet has soldered wires but the C14 uses some kind of crimped connector. They're attached very firmly but it's still a scary thought that they can get loose
- The split AC inlet is a nice idea but again I find it a bit scary to have loose live wires in my build when not using it. I'm thinking of soldering my own wire that's not split
morj
366
698
Germany
Got PSU, has the short 24pin cable as well. The color is very nice in person. 24pin retention clip will indeed protrude when inserted. Generally, I'm not a fan of the wire on the back as well, adds length. Ultimately, you can't count on the length being 170mm, better to have ~180mm length inside the case to be able to mount reliably.
hmpf
Hi there, just wanted to share what HDPlex shared with me after I inquired about low wattage efficiency:
 12V 5V 3.3V  5Vstb
Efficiency 115VAC230VAC 115VAC230VAC 115VAC230VAC  115VAC
1A78.6%76.0%60.0%64.9%42.5%38.6%1A54.4%
5A89.1%89.2%80.4%81.4%75.0%76.8%2A57.1%
10A91.3%91.8%82.5%82.5%81.3%81.5%3A62.0%
15A91.5%93.7%
18A91.9%94.3%
20A91.3%92.3%
23A91.0%92.1%
lemmo
48
30
Thanks for this hmpf, it's a useful enquiry.
Please can you give an idea how this compares to other power supplies, e.g. non-GAN or Pico-PSU?
And does this indicate that the HDPlex GaN is a better option for power-hungry builds 200W+ but less less so for low-power build 100W max where a system may be sitting idle much of the time?
Reactions: k0n
k0n
264
364
Wasn't home when it eventually arrived. Yesterday I finally could finish up my build... The 24pin retention clip had to be removed.
Very happy with the PSU.
The riser is dual reverse and the same length that is needed for a sandwich layout (~18cm). ~1mm to little space between 8Pin cable of the card/24pin on the PSU and 24pin retention clip/case of the PSU.
Reactions: BaK
hmpf
Sorry I just saw the table got shifted a little and I dont know how to edit posts, so here again:
 12V12V 5V5V 3.3V3.3V  5Vstb
Efficiency 115VAC230VAC115VAC 230VAC115VAC230VAC 115VAC230VAC
15A91.5%93.7%
18A91.9%94.3%
20A91.3%92.3%
23A91.0%92.1%
@lemmo:
Yeah if your rig is very low power, the efficiency drops a lot. unfortunately there is no data point between 1A ( ~12W) and 5A (~60W). I considered using it for my system which will draw ~30W / 2.5A in idle, but I opted for the silverstone SFX PSU which is much cheaper and according to them has 85% efficiency @60W, no lower wattage data is available. The HDPlex might be better at 30W, but I think not so much to justify the extra 100€ price tag. I guess if your system draws >50W it is a no-brainer.
k0n
264
364
@lemmo Thank you for the info, really would like to know what is going on there. I'm working on a case that is designed around the HDPLEX 250W GaN and187x60x32mm does not fit XD
Reactions: thelaughingman
thelaughingman
1,410
1,564
Oddly enough, another 250W GAN power supply has popped up: the Pico-Box GAN-ATX-250W.
It is slightly bigger than the HDPlex, at 187mm x 60mm x 32mm, but cheaper at $99. Otherwise details are sketchy.
I don't know if Pico-Box are the OEM for the Pico-PSUs and other ITX power supply components, or a copycat, or a distributor...
wonder who would be able to do benchmarks for both this one and HDPlex hahaha
protocolsix
29
 12V 5V 3.3V  5Vstb
15A91.5%93.7%
18A91.9%94.3%
20A91.3%92.3%
23A91.0%92.1%
I thought the HDPLEX 250W GaN had max 20A for 12V (240W) but this table shows 23A, which implies 276W max...
I've read that the OCP is 300W, so it sounds like it might support higher draw than 20A?
TheJiral
56
144
Is that Pico-Box PSU still sold? Can't find it on their website and the link is dead. Anyhow, I already got a HD-Plex 205W GaN.
You had me shocked there in the initial post with only 82% or so on 230V AC. That would have been pretty insane. Cool to see efficiency numbers for different loads.
So I can get an idea about the TDP of the PSU in my project. At the projected heavy load wattage of 180W, that would mean ~10W TDP and at 240W a ~18.5W TDP. The latter is already a bit worrying, even with my custom PSU heatsink without active air movement in my case. But I would not expect such high constant load.
Has anyone figured out in the past 3 years why the 23A are in that list? Did HD-Plex downgrade the rated wattage to 240W at 12V due to thermal reasons but the PSU would be capable of handling transitional higher peaks of up to 270W?
