CPU HDPlex GaN 500 mounting brackets
hrh_ginsterbusch
702
274
wp-devil.com
Because this just popped up as an issue in my build:
It'd be SOOO swell if HDPlex would create an SFX mounting bracket, whether as a simple one-size-fits-all thing (eg. mount in the middle and be done with it) or as a more flexible variation, like: Position to the left, middle, right or so. I'd happily help testing it, too.
So, design-wise similar to like the SAMA IM01 SFX PSU mounting bracket (that should be identical to the NR200 one), but for the HDPlex GaN 500 and maybe also 250. Combined maybe with an additional L-bracket that keeps the bottom part of the PSU secured as well. So either the power cord points up or down, depending on the setup.
Design-wise, this could be mounted as a side mount (NR200, SAMA IM01, or even A4-H2O), front mount (NR200, SAMA01, and even AP201) or even horizontal mount (eg. Silverstone SG13 or SG05).
I know there are some 3d printed variants, but for one, you need access to a 3d printer - which I dont have - and also, I feel something made from eg. solid steel or aluminium would be much more reliable.
cu, w0lf.
