I did but decided I liked the look of the butted joint better. That way the bottom joint mirrors the top when the lid is on. There are dowels supporting the butts.
one possible future change is moving from aluminum to steel for internal support. The rear panel gives rigidity to the side panels, but unfortunately, the aluminum is too flexible to provide the same and the front edges of the side panels bow out a bit as a result.
Unfortunately only I only have the tooling to work with aluminum.
