What are the recommended clearances from the cooler of a reference GPU to the edge of the inside of the case? Since my GPU will have a riser, what's the recommended clearance from the back of the GPU PCB to the edge of the inside of the case? Also, if I have a 266.7MM/10.5" GPU, what would the minimum length of the inside part of the case? I can't figure out how much space I need.
