Motherboard Gigabyte B550I AORUS PRO AX ITX
Klasik
welp, bought this board for Ryzen 5900X, and the Q Flash Plus feature just doesn't work.
It is either very picky about USB flash drives or I got a lemon.
b0ykie
Did you ensure the thumb drive was formatted as Fat32 and renamed the bios file to GIGABYTE.BIN? Also you have to remove every component except the 24pin and 8pin connected to the motherboard for qflash to work. That means no GPU/RAM/CPU/Drives installed. Check this video out for more details.
b0ykie
Has anyone tried out the F11d BIOS yet?
Yeah I did. Fixed a weird issue for me which I had to clear the CMOS everytime I unplugged the mains from the socket. Very weird indeed. Luckily F11D did fix it so no complains from me. Performance wise don't see any differences. Could hit 1833 IF no sweat on both bios-es.
Klasik
Yes. Did all the necessary steps.
1. Downloaded BIOS from gigabyte
2. Reformatted the drive to FAT32 (even tried FAT16, as I read that it worked for some)
3. Copied the B550IAPA.11d to the flash drive and renamed it to gigabyte.bin (tried all kinds of capitalization)
4. Motherboard only has 24pin and 8pin power connectors plugged in (and is getting power)
5. When I press the Q Flash button, the flash drive LED flashes once and nothing happens
Tried with 5 different flash drives I could find in my home.
I read that someone managed to get into BIOS with 5900X, so I will try to hook everything up and try regular Q Flash once my RAM sticks arrive.
Arie
37
70
I couldn't get q-flash to work while the board was hooked up to a Corsair SF600, but when I switched to my older Silverstone SFX-L 500W PSU it worked without issues.
Klasik
Interesting. I have SF750. I will try a different PSU then.
UPDATE: Tried with an older CoolerMaster ATX PSU and it didn't help. Flash drive LED flashes once and nothing happens. If anyone has any other ideas, I'm all ears.
maveric
27
Is anyone using this mobo with a Zen 3 CPU and a RTX 30-series GPU without problems? It sounds like some are reporting USB issues on Reddit.
tja4430
39
45
For anyone looking to update to F11G looks like there are some issues (reddit discussion).
I've got this board in a Sentry 2.0 case running a Ryzen 5 3600 at 4.0 GHz at 1.148 VCore with XMP Enabled (DDR4-3200 CL16). Haven't had any issues with any BIOS so far.
I've been using F11g for 2 days with zero problems.
It seems like these new BIOS aren't quite the most stable for the new Ryzen 5000 series though.
Mackan
282
156
If possible, can someone check at what distance the armor on back of the motherboard extends from the pcb? It basically decides how long motherboard standoffs I need.
gusto5
Gigabyte recently released a new Realtek LAN driver (10.47.121.2021) which they're claiming to fix random LAN disconnections. Just FYI everyone!
Reactions: AlexTSG
