General Chat Thread
BirdofPrey
Standards Guru
Sep 3, 2015
797
493
That would be lovely yes. Thanks a lot.
Edit: Chokes seam to be pretty low profile, but I can't tell until I receive the board.
You SHOULD be fine. Much of that corner of the motherboard has a height restriction to allow for heatpipes of a low-profile blower cooler.
Of course, that's not a guarantee, sometimes manufacturers do make out of spec stuff.
Reactions: Soul_Est
Ceros_X
747
660
US
So I found out that Silverstone has this board (ECP01) that adapts Molex to a 12V 5A plug (with overvolt protection and all), and was wondering if I could get a simple cable instead. Is it safe to power a display straight from a PC's PSU? Looking to power a screen controller board with it.
EDIT: wording. Pleh
I'm just a savage so I chopped the adapter cable that with the screen controller board and then spliced it into a spare molex extender. Hooked it up to my SF450 PSU and no issues. It has been working without incident for 6+ months.
Deployment Box
No shot of the splice but there were only two wires and it was super easy.
If I would have known there was an adapter like that I would have picked one up, in retrospect (not that I will ever need to plug it into a wall again).
Reactions: VegetableStu
VegetableStu
1,949
2,619
That adapter's a new release though. Not sure when it'll hit amazon or the stores. I'll have a look at them again once they do
Not sure it I should commit to my current salvaged 15" 1280x800 panel, or get a higher resolution 15" panel though. I'm thinking of using that as the primary monitor (but not for main/colour work, I'll be using a seperate monitor for that)
VegetableStu
1,949
2,619
Eh, I personally would get at least 1920x1080. I picked up a new panel off amazon for $80 -- they aren't that expensive. Make sure you figure out how you'll mount your screen before you order it.
Yeah definitely. I'm thinking of just making it a flat board (with the controller on it), and cabling about a meter straight to the PC. I'll get this part going after getting my next PC. Which seller did you get your display from? o_o
1461748123
489
1,068
I was browsing my sketchup library today and I realise I met @Aibohphobia way before I notice sff.net:
Pretty crazy XD good thing I did gave credits!
iFreilicht
FlexATX Authority
Feb 28, 2015
3,243
2,361
Germany
freilite.com
Man, this keyset is looking so damn good, I'm really contemplating whether to buy it when it's released, but with all the keys I need/want, it's probably going to cost a hundred bucks or more. :(
Reactions: jØrd
Arboreal
874
877
58
Sunny Bournemouth, UK
Wow! I didn't know that it was called that.
When I saw it, a dim lightbulb lit up and the words Mother and Keyboard appeared in my head.
Followed by something tall & black scuttling past in the shadows...
