So I have been using the same mouse for the past 12 years or so, mainly because there was nothing really wrong with the mouse and it was comfortable to use. Now, the mouse buttons have worn out and will randomly trigger a double-click instead of a single click. I've tried cleaning it to see if dirt or dust was affecting the sensors, but there was no difference afterward. Soon enough, this was happening for multiple buttons on the mouse, and they were buttons I frequently used.
Leading me to believe that the mouse buttons themselves were worn out.
The current mouse I'm using is the Razer Lachesis. They obviously don't make that mouse anymore, but I haven't been able to find a low arch mouse like it from the current offerings.
I don't really like the high arch mice as it makes my hand tired after about a hour of use.
I'm essentially looking for a low arch based mouse with the same or higher dpi as my current mouse, with at least 5 buttons. I especially like mice that you can "death grip" if you know what I mean. Mice with grooves for the main mouse button are a plus.
