CPU Game Mini Pc (VX1) from Aliexpress (12700H + 3060 12GB mobile)
CobraG
To create a working driver, basically download NVCleanstaller
and then use the following settings:
Select: Manually select a driver version
Check box: Show all versions
From the drop down list select the latest driver version (at time of writing its: 546.01), so I selected: 546.01 Windows 10 64bit Notebook DCH
Make sure you select Notebook and not Desktop
Click Next
On the "Select Components to install" screen, make sure at least the following are checked:
[X] Display Driver (required)
[X] PhysX
[X] HD AUdio via HDMI
[X] Microsoft Visual C 2017 Runtimes
Click Next
Wait for it to "Prepare sources..."
On the "Installation tweaks" screen, select the following:
[X] Disable Installer Telemetry & Advertising
[X] Add Hardware Support
From the drop down Template select: GeForce GPU [134B.0008.1414] nvmsoig.inf
Add the last 4 digits: 2520 to the (ID), so that the whole line reads as follows: PCI\VEN_10DE&DEV_2520
type the name in manually: Name: GeForce RTX 3060 Laptop GPU
[X] Rebuild digital signature
Click Next
On the "Finished" screen select: Build Package. This will create an install file for you. Run it as you would a normal nVidia driver install and enjoy.
I hope you still check this thread. I have Chatreey Tank Mini PC with NVIdia GeForce RTX 3080 + Intel Iris Xe Graphics
so when I get to the "Installation tweaks" screen and tick on "add Hardware support" in template search bar only GeForce GPU option I have is GeForce GPU [1392.066A.1028]nvdmi.inf as seen on the screen shots
on 2nd screenshots you can see installed DEV_249C since I used Fraken Driver
LukeD
529
1,338
Sydney, Australia
That's because you started typing "GeForce..." and it limited your results. I just checked the tool and the latest version of the driver and I can select any GPU from the drop down.
As a matter of fact, one of my later updates says to select: From the drop down Template select: Quadro RTX 3000 with Max-Q Design [1F36.0032.1414] nvmsoig.inf
And then add your device ID after
CobraG
Well the template Quadro worked but the PC still crashes during games. Chatreey Tank Mini PC with I9 12900H 3080 16G, 32G RAM 1TB SSD bought on Aliexpress on 23rd of December 2023 (2 things bought on ALi and both seems to be faulty so most likely won't buy from there anymore) it seems to have defects. The Display Port is not working, when connecting cables to the HDMI's, system crashed (or the video crad) with the smell of smoke/burned so I though it's done but after disconnecting the cables and the power suply and waiting for approximately 30 min, connected all the cables back while the PC is still shuted down, so it was working once again so I no longer touch cables while the PC is running but the so called "gaming PC" crashes during Games let's say after starting the PC if I can play for an hour then will crash with black screen (sometimes there are colour lines) with sound similar to buzz or "rrrrrr" some would say and it crashes on games like Sven Co-Op (gold source engine those who are familiar with Valve and Half Life) and I was hoping to run with this "beast" Killing Floor 3. I went to guy with service shop for repairs right after the 1st crash with the smell, I explained the situation and he told me he wouldn't even bother to open the PC, most like there is an hardware issue and it's best to return it which is imposible since I open the box and started to use the PC since January this year (was too lazy to transfer my stuff from my laptop to outer disk before moving to the mini PC). So is there any hope to improve this tank or should move on and looking for something new, anyone who have this problem with the crashes and find a way to improve it or fix it? Here is screenshot from the last crash
This are screenshots from CPU-Z and GPU-Z
I wrote on reddit, on some MiniPC's forum where I was told Chatreey is not a brand supported by AceMagic even that both tanks are clones, on live chat of the chatreey's support ( they said will ask their engenier and send me an email, till now nothing) and from nowhere I got any help so far, is there something that can be done (like reinstaling OS, some other drivers etc) or the PC I have is just junk?
