Log First Time building SFF (ncase m1)
Rockaholic
Hi All,
This is my first time building SFF.
Cable Management was easy due to Custom length cables. The most painful part is tightening the EK fat 90-degree Quantum fittings in tight corners as it has no proper grip and I have to use lots of pressure on my fingers until the fingernails recede a little.
I've left the RGB while taking photos for those who are thinking of add RGB. Usually, I would just turn it off.
PC Parts
Case: Ncase M1
Processor: AMD 3950x
M/B: Asus ROG Crosshair VIII Impact (X570 Mini-DTX)
GPU: ASUS EKWB GeForce RTX 3090
Ram: G.Skill Trident-Z 32 GB 3200Mhz (OC 3600mhz) [recycled from previous RIG]
Storage: Samsung 970 1TB Pro M.2 and 980 1TB Pro m.2
PSU: Corsair SF750
PSU sliver cables are made by pslate customs.
Fans: Noctua NF-A12x15 PWM and NF-A12x25 PWM
Water Cooling Parts
CPU WaterBlock: EK-Supremacy EVO Elite Edition [recycled from previous RIG]
Radiators: A pair of XSPC TX240
GPU WaterBlock: Preinstalled EKWB
Reservoir: IceMan Cooler
Pump: Switftech DDC with PCB board replaced with DIYINHK.
Fittings: EK 90 Degrees Quantum and Classic fittings, Koolance soft tube fitting ID:10mm OD:16mm,
Quick Disconnect: Koolance QD4
Hardline pipe: EK Static Extenders and Koolance adjustable Extenders.
Soft Tubing: Primo LRT ID:10mm OD:16mm
Coolant: Koolance LIQ 705 with Mayhems Inhibitor + Biocide added
