Hey everyone. So I have a hook at EKWB for parts but I need to place the order all at once. Originally I wanted to get the blocks first then work out the fittings but that wont be the case. Here are my questions:
1) Bottom mounted radiator: I want to get an extender for the bottom radiator fittings so that it will clear the 15mm Noctua fans AND clear the top of the GPU waterblock so I can put a 90 degree elbow directly to the GPU block. How many mm extender do I need?
2) The side mounted radiator, I was going to do 28mm extenders wiht a 90 degree elbow and Koolance QD3's. Will I have clearance issues between the noctua 25mm and the PSU?
3) CPU block: I was going to get a 30mm extender to clear the ram and a 90degree elbow to work its way to side radiator fitting in question 2. Will this extender be long enough?
4) is a 13mm/10mm EPDM tubing good enough? or is a 16mm necessary? will 16mm even clear?
5) Please have a look at my tentative fitment setup below. I would appreciate any help before I place an order.
Thanks guys.. I appreciate any help.
_____________________________________-
Ryzen 3700X
Nvidia RTX 2070S
Asus Rog Strix 550i Motherboard
Vengeance LPX Ram 3200hz 2x16gb
NCase M1
WaterCooling Items:
EK-Quantum Vector RTX RE Ti D-RGB - 2070 Super WaterBlock
EK-Quantum Velocity AMD - Ryzen 3700x / Asus B550i Mobo
Iceman Reservoir / EK DDC 3.2 PWM Pump
Bottom Mounted: XSPC Slim Radiator / 2 x Noctua NF-A12x15
Side Mounted: XSPC Slim Radiator / 2 x Noctua NF-A12x25
Tubing: EPDM ID 3/8 x 1/2 OD (13/10mm)
Quick Disconnect: Koolance QD3 MALE / Koolance QD3 FEMALE
Loop Configuration
Res/Pump > GPU > Bottom Radiator > Side Radiator > CPU > Res/Pump
Loop Configuration in Detail
Iceman Reservoir / EK DDC 3.2 PWM Pump:
IN(From CPU): 1 x Rotary 45 degree /// 1 x EK-Quantum Torque STC 10/13
OUT(To GPU) 1 x EK-Quantum Torque STC 10/13 Out
EK 2070 Super Water Block:
IN(From CPU) - 1 x Rotary 90 degree /// 1 x STC 10/13
OUT(To Bottom Radiator) - 1 x Rotary 90 degree /// 1 x STC 10/13
Bottom Radiator:
IN(From GPU) - 1 x EK-AF Extender 20mm (To clear fans which are 15mm) /// 1 x Rotary 90 Degree /// 1 x STC 10/13
OUT(To Side Radiator) - 1 x EK-AF Extender 20mm /// 1 x Rotary 90 Degree /// 1 x STC 10/13 /// Koolance QD3 Male
Side Radiator:
IN(From Bottom Radiator): 1x KoolLance QD3 Female 1 / 1 x STC 10/13 / 1 x Rotary 90 / EK-AF Extender 28mm (To clear fans which are 25mm) / 1 x Rotary 90 /
OUT(To CPU): 1 x EK-AF Extender 28mm / 1 x Rotary 90 / 1 x STC 10/13 / 1 x Koolance QD3 Male
CPU:
IN(From Side Radiator) : 1 x Koolance QD3 Female /// 1 x Rotary 90 /// 1 x EK-AF 30mm Extender (To Clear ram)
OUT(To Res/Pump): 1 x rotary 45 /// 1 x STC 10/13
Ryzen 3700X
Nvidia RTX 2070S
NCase M1
WaterCooling Items:
Loop Configuration
Bottom Radiator:
Side Radiator:
CPU:
