Fanless Ryzen+Polaris Project
Discussion in 'Build Logs' started by Zgembo, May 20, 2017.
  1. Raiju
    Raiju Cable Smoosher
    #21 Raiju, May 26, 2017
    Well done, our setups for the gpu look quite similar. Can you please run firestrike?
    With my latest stable overclock I score 8271 for graphics (physics: 5896, total: 6631). You should get a much higher Physics (and overall) score having 8 cores and all.
    My build
    [​IMG]
    Here is where we differ a bit
    [​IMG]
    Oh and I used the hdplex for the cpu too, only one panel since have the psu internal
    [​IMG]
    Acalanata, Phuncz and Zgembo like this.
  2. Kooki
    Kooki SFF Lingo Aficionado
    Very nice builds, guys!
    It's very impressive what this case can achieve. I wans't expecting the RX 570 would work in it as well as it did!
    I also really liked how you put heatpipes in "series", Raiju.
  3. Zgembo
    Zgembo Trash Compacter
    Thread Starter
    After hassle with 3.7 gigs of 3DMARK bloatware download & setup, just for you :), here it is
    [​IMG]
    Note that this result is with slightly more aggressive GPU VBIOS power settings... I've increased TDP from 85W to 90W & max GPU power from 90W to 100W in my latest GPU power optimization attempt (I did decrease GPU power state clocks and voltages as well), which seems to run stable, although just slightly more hot.
    Nice job with that dual pad, I wish I did the same, but had only one pipe left... BTW, greasing up the whole length of the pipe that touches the chassis body may help dissipating the heat even more quickly.
    I'm totally curious how did you do that VRM MOSFETs heat-conducting part. Apparently it reaches the chassis aluminium plate. Care to share the details?
    And those blue passive heat-sinks, where can one buy 'em?
    Raiju likes this.
  4. Raiju
    Thanks a bunch, I was really curious, you got a nice score there.
    Grease on the heatpipe, I realized that later too looking at my own pics. I am rebuilding 1 final time so I'll do it this time. I am running the cpu die naked and need to make an adjustment to the plastic of the socket, while I am in there going to replace with a 4 core cpu.
    As for the vrm's, I used a Thermalright hr-09 type-2 I had laying around and was happy I finally found a use for. It didn't quite reach the panel but the included cpu shim was perfect for overcoming that. I drilled two holes in the hr09 and bolted it to the pcb, the shim is glued on (made my own thermal glue, epoxy mixed with aluminiumoxide powder)
    [​IMG] [​IMG]
    The blue heatsinks are from Zalman, ZM-RHS1 I think. Oh and I got a corsair sf450 in there:cool:
    Zgembo and Phuncz like this.
  5. Kooki
    You mean to tell me that that thing I can't really identify is a SF450? õ-o
  6. Zgembo
    Thread Starter
    Oh, an alchemist, impressive! Doing those kinds of mixtures is way beyond my patience level.
    And that HR-09 thing is from some other era, too bad nobody's selling anything similar any more :(
    I've searched the whole damn Internet deep and wide in vain... Does anyone know if anything like this
    [​IMG]
    can be bought for some honestly earned hard currency anywhere?
    SeñorDonut likes this.
  7. Zgembo
    Thread Starter
    #27 Zgembo, Jun 9, 2017
    Time to finalize this build log...
    After playing for days with Sapphire Pulse RX570 ITX VBIOS modding, I've got to the the point of what I think is an optimal balance between card power usage and performance under thermal conditions for this build. I've set the max VBIOS power to 85W, but also had it under-volted to its limits, as well as under-clocked in higher power states. I had to learn how to adjust power states voltages, down-clock hem, even adding proper VDDC voltage offset registers to the VBIOS from scratch, not to mention adding special UEFI GOP. An interesting learning experience, indeed, if one don't mind the risk of bricking a brand new and by no means cheap graphics card...
    I did expect to go through this kind of hassle when I decided to go with Sapphire R750 ITX, but for those that may to build similar system without any such worries, properly sized RX560 or even GTX1050 might be much better choice. Same can be said for CPU, perhaps a Ryzen 1600 would never even reach the throttling point in this setup?
    That said, here are some final touches I did to my black obelisk build... One final metal mod had to be done to officialize the friendship between Stracom chassis and HDPlex PSU. Two small holes were needed on the power lid plate provided in the chassis set so that Strecom and HDPlex can stick happily together for the rest of the lifetime of this box.
    [​IMG]
    The lid plate fitted nicely, as can be seen from below.
    [​IMG]
    Finally, I added a pair of Plextor SSDs, both tightened to a single DB6 metal bracket.
    [​IMG]
    Because the aluminium heat blocks are now firmly attached to all four sides of a main chassis body, there is little room left for hard drives, which is exactly the reason I'm using single bracket for two drives. But with careful placement, there is just enough space left for one more such pair if needed. In that sense DB4 is really remarkable, even in this hybrid and highly cramped setup I could have had added total 5 storage devices (1x M.2 below the MB & 4x 2.5 inch SSDs) if I really wanted to.
    [​IMG]
    That is it, after all pieces put together, this is what the final "product" looks like...
    [​IMG]
    And how does this thing run? I've just played Witcher 3 for about 3 hours, with all graphics settings maxed out @ 1920x1080, it runs very smooth... Under that kind of load the GPU temp never went over 74C, and the CPU never above 70C. These longer running loads makes the chassis dissipate the heat nicely an evenly across the surface, although when touching certain parts of the aluminium heat-sinks one can feel as if it almost going to burn your fingertips. The only things that worries me a bit, temperature-wise, are VRM heat-sinks, on both MB & graphics card. Both have just a small passive heat-sinks now, which by no means conduct the heat outside of the chassis. I wonder if there is some relatively simple way to connect them to the chassis with at least a sole heat-pipe... Suggestions are more than welcome!
    During this quiet night Witcher 3 session, especially when rendering some graphics intensive scenes, there was this barely audible fan noise coming from the case... ?!? Wait, what fan noise? Yep, it was definitely a noise, not coming from some non-existing ghost fan, but from Sapphire RX570 ITX VRM coils. Surprisingly, the coil whine on that thing is really obvious, especially on a quiet night with minimum ambient noise. It is also inconsistent, so it is worse when the card is under heavy load, and it sometimes sings in somewhat annoying synth-punk-like patterns. I bet it could be heard even if that stock GPU fan was on (BTW, a stock fan WAS pretty quiet when I tried it, even under load). The coil whine got little less obvious when I further under-volted the card, but I still have to learn how to live with it. Luckily, there are absolutely no audible coil whine coming from motherboard or PSU or GPU when graphics is idle, no matter how high the CPU load is. Biostar B350GTN MB and HDPlex DC PSU are quiet as they can be, it is only the Sapphire that becomes somewhat noisy under graphics intensive loads, benchmarks especially.
    In Linux I have still to run workloads that would bring the temperatures significantly up, under standard desktop activities the chassis was uncompromisingly nice & cool & quiet, like I always wanted these things to be :)
    Overall subjective impression; I'm happy with this black box, hope it would serve me for years to come.
    Acalanata, Karamazovmm and Phuncz like this.
  8. Phuncz
    Phuncz Lord of the Boards
    Moderator Gold Supporter
    Zgembo likes this.
  9. Zgembo
    Thread Starter
    Interesting, these two Halteprofile... The info on site doesn't actually say if they are meant for 6mm heatpipes. Now I only need to go to Germany to get some :)
  10. Kooki
    Did you guys use glue on the VRM heatsinks? How are they sticked in place?
  11. Zgembo
    Thread Starter
    For GPU I used some cheap aluminium heatsinks I found in random Akiba shop, and they already come with a thin layer of adhesive. I think this is the weakest part in my build, ideally those VRMs should be heat-piped to the chassis plates, like @Raiju did. I simply couldn't find an appropriate way to fix a heat-pipe to VRMs (not that I tried too hard).
  12. Raiju
    I got a pm from Kooki asking about the sf450 I used. Here is what I did:
    I mounted motherboard standoffs on one of the panels
    [​IMG]
    The thick pad that comes with the case was perfect for the vrm's
    [​IMG]
    nice contact with panel
    [​IMG]
    And I glued on some heatsink just to be sure
    [​IMG]
    This case is running 24/7 since mining eth lol no overheating issues what so ever.
    I use the igpu for monitor so I don't notice anything
    Kooki and Zgembo like this.
  13. Lisao
    Lisao What's an ITX?
    You inspired me to make a simular build.. great work!
    Could you go more into detail of how you did the VBIOS modding of the RX570? Are there any easy instructions an beginner could follow?
  14. Zgembo
    Thread Starter
    A bunch of VBIOS mod iterations... First i just spent some time in soft underclocking / undervolting in Windoze, looking for power/thermal/performance sweet-spot. Once I had that, I fired polaris bios editor and and set the power states clocks and voltages to those sweet spot values and flashed that to the card. Next step was to restrict TDP & Watt limits. Finally, I added the power offset datastructure to the VBIOS, but this didn't provide very significant benefit, and is pretty complex operation.
    One can get some education about the process at http://www.overclock.net/t/1604567/polaris-bios-editing-rx5xx-rx4xx. And most importantly, there is a risk involved into VBIOS modding, so be careful & do proper backup.
    Phuncz likes this.
  15. WildWhite
    WildWhite Efficiency Noob
    So how has this setup turned out? It seems like something I want to do, with a ryzen and probably a gtx 1050/1060 or something good under 300.
    I have been looking at other high powered passive solutions, the calyos is to abit to large im my thoughts.
  16. Zgembo
    Thread Starter
    Ever since being built, the box is up ~10 hours of the day on average, mostly used for standard net browsing and playing videos, some heavy rendering, occasional maxed-out dual-monitor 1080p gaming and emulators (Super Mario @ Dolphin @ 1080 makes the temps go above idle for only 3-4C). Linux is running great, ever since I RMA-ed the CPU due to the infamous Ryzen segfault issue. The idle temp is @ ~42C (both CPU & GPU), VRMs @ 55C and the M2 SATA drive @ 60C. I've put 4 SSDs in the box, one pair in RAID1, and other two stand-alone. The two SSDs that actually do report the temperature under Linux, sais they are at 60C when idle.
    And the level of the noise it (does not) make is priceless. I'm pretty happy with the thing.
  17. Kooki
    This is beautiful.
    The PSU looks much tinier. lol
  18. lebodaryo
    lebodaryo What's an ITX?
    Thanks so much for this write up. I'm thinking of doing something very similar for an office build.
    Knowing what you know now and considering the new hardware that's come out since you did this, would you have used any other parts for this build?
    You mentioned Biostar not allowing under-volting so maybe a different MB.
    The GPU seems like something to think about.
    Thanks again.
