Been a while since I stopped in. Glad the forum has picked up!
I've been sitting on a design for a while now that I really want to have manufactured (far from that point; all I have is a mock-up at the moment). The whole design depends on how well a section of a large fan placed over a CPU heatsink would be able to cool the CPU.
This would be a C7 heatsink (with no fan of its own) on an i7 6700 (non-K), so relatively low TDP (~65W, IIRC—vs the C7's 100W capacity) What do you guys think? I'm also working with the presumption that this would be a Noctua fan—specifically the 200mm that is coming out soon.
The heatsink and fan are scaled properly, but the heatsink placement isn't exact.
Here's an actual shot with component models:
I'm mostly worried about how much the bearing housing and the frame would affect air flow. From what I understand, Noctuas push a lot of air. I don't know what the static pressure of the 200mm model will be, but their fans usually have decent to high static pressure. I'm wondering if this much coverage would be sufficient to push air through the heatsink fins under those spots.
