So...
Coming from a Caselabs M8 i wanted something smaller since my watercooling days are over. I went for the LianLi TU-150, since it can fit a beefy cooler.
So initally i put my trusty Dark Rock 4Pro in to the case, but it seemed to restrcit the airflow for the rest of the components. Switched over to a Arctic Freezer 34 that was in my sons pc, and it seems to work a bit better, alteast the noise is down a bit. All in all i was not expecting this level of noise , so is to be expected ?
Specs are:
Ryzen 3600
Gigabyte x570 (my b550 order got pushed to august)
Asus Strix 2070s
16gb trident neo
960evo/860evo
Memory controller temp pic
Edit: Forgot to add that i use noctua for intake/exhaust. NMo room for fans under the gpu.
Specs are:
Ryzen 3600
Asus Strix 2070s
16gb trident neo
960evo/860evo
