EVGA's power cable relocator is dope
7,151
Too chunky imho. I can't see it saving any height over just a regular plug with the wires flattened out
IntoxicatedPuma
Customizer of Titles
992
1,272
I like it, I'd totally go for that.
I'm guessing they might release something like this for CPU and 24 pin connectors for the 200 series boards?
Josh | NFC
Not From Concentrate
NFC Systems
Jun 12, 2015
1,869
4,468
www.nfc-systems.com
Like I said, its the concept I'm digging. I would love to see hard PCB with small wired bridges in the future. :)
Chunky or not, for cable management buffs it is a PITA to get your wires to the side of your cards and not have them dominate the case.
jØrd
S̳C̳S̳I̳ ̳f̳o̳r̳ ̳l̳i̳f̳e̳
sudocide.dev
LOSIAS
Jul 19, 2015
818
1,359
would be really nice if they rotated the input sockets to the same direction as the fans (if that makes sense)
aquelito
Piccolo PC
Feb 16, 2016
952
1,123
Would be of great help for my build !
Nice to see some actual product design innovations, not only the usual power race...
In the meantime, do you know any 90° angled 6Pin cable ? Such as used in Alienware builds ?
Reactions: Josh | NFC
KMPKT
3,382
5,936
I don't have the expertise for this, but I've thought for some time it would be cool if someone could design a right angled 6 and 8 pin connector for the community to be able to 3D printed for builds. Any takers?
EdZ
Virtual Realist
May 11, 2015
1,578
2,107
3D printing on a desktop FDM machine might be tricky; these are high-current connectors, I'd be wary of both the insulating properties of 3D printed thermoplastics, their mechanical properties (could be tricky to print parts that do not separate along a layer join when inserting/removing) and their thermal properties (melting from resistive heating of conductors/pins). Injection moulding would definitely be preferable.
Curiosity
Apr 30, 2016
713
832
To me it looks a little slimmer than regular connectors, or at least as thing if they're flattened.
I'd like to see 1x6pin/2x6pin/ other variants of it.
iFreilicht
FlexATX Authority
Feb 28, 2015
3,243
2,361
freilite.com
That is very interesting, but it's much too chunky to be advantageous right now, IMO. If they can achieve a profile where it doesn't just look like a cable in a fancy housing, this could become widely used in SFF builds.
