Just noticed this on their facebook page. Asked for more details. Just thought I'd post it here for the peeps...
About 1.43L I think, 780W 90% efficiency. Not too bad although I must admit that logo is a bit much. Also the vents would scare me as external power supplies are usually sealed. But good on them for innovating.
4.3” / 110mm Width
12.8” / 325mm Length
1.5” / 40mm Tall
72.9” / 1854mm Cable Length
Total weight: 3.05 pounds / 1.38 kg
Vital Specifications
Rated Output Power: 780 watt
Input Voltage & Frequency
The range of input voltage is from 90Vac to 264Vac.
Input Frequency 63Hz 50/60 Hz 47Hz
Input Current
The maximum input current is 10A at AC Input 100Vac/60Hz.
Inrush Current
The inrush current will not exceed 100A at 230Vac/63Hz AC
input for a cold start at 25℃.
Power Factor
The Power supply power factor at full load operation shall be
more than 0.9 at 230Vac input.
Efficiency
The efficiency (watts out / watts in) higher than 90% typically
while measuring at nominal line and maximum load.
Output Requirements - Static Load
Output Voltage: 20Vdc
Minimum Load: 0A
Maximum Load: 39A
Peak Load 45A (duration Time 25ms)
Line Regulation 2%
Load Regulation: ±5%
Voltage Accuracy: Min 19V Max 21V
Ripple & Noise(*) 200mVp-p
1.5” / 40mm Tall
Input Current
Inrush Current
Power Factor
Efficiency
Minimum Load: 0A
Maximum Load: 39A
Line Regulation 2%
