Discussion entry lvl 3D printer to make my own cases ?
Kam7r
Hi sorry if this has been asked quite a lot,
I would like to start making my own cases, i'm really a newbie in 3D printing, and looking for a first 3D printer at a low cost to start learning and making my first ones
I know that i need to use ABS for the material resistance to heat ( but i heard PETG can do too ? ) and a surface printing of 220x220mm
Do you have some recommendations on a low cost model i could buy from Geekbuying to start ? Speed is not a big factor right now, i'm really looking for something affordable that can do ABS decently , relatively easy to use and a box ( yea, maybe it's too much ^^' )
thx a lot guys
REVOCCASES
2,256
3,694
Germany / HK
www.revoccases.com
Coming from an 250,- CREALITY ENDER, I'd recommend to spend a little more and get a good mid-range printer instead. Printing anything except PLA with the ENDER was just frustrating and slooooooooow....
I'm now pretty happy with the Qidi +4 printer...
QIDI Plus4 3D Printer – Qidi Tech EU Online Shop
The FLSUN T1 Pro is also nice...
Flsun T1 Pro – eu.store.flsun3d.com
And of course there's BambuLab
eu.store.bambulab.com/de/collections/3d-printer/products/p1p-de
As for material, I had very good experience with PCTG
PCTG filament - for the highest industrial requirements - Extrudr - High Quality Filament
Mrgravia
I have a very much modified gender 3 v2, and yeah, topping out at about 150mms means printing even a small itx case can take over a day. I’m prepping for a killer conversion though, but it’s still underway.
if you don’t already have a printer, I’d second going with something more modern and larger. Quite a few used ones out there as well you can get for a pretty good discount.
Reactions: Kam7r
Mrgravia
Should add the newly announced Elegoo Centauri is a bargain. Core XY, 256x256x256 build area, 500mms speeds.
199 for the open frame, and the enclosed and upgraded Centauri Carbon is 299.
Reactions: Kam7r
