Hi Folks,
I have the nice and loud NUC Skull Canyon and I'm looking for a eGPU in the footprint of the NUC, since we have today both GTX 1060, and 1070 in ITX format out that should be possible, Sure I could go, buy a Akitio Thunder2, or 3 case, and do quite some DYI on it to get it working. (although this is a nice option, I dont feel so confident in the powersupply soldering) and that is already discussed here.
So what about combing the PCIe Beast:
http://www.banggood.com/Mini-PCI-E-...dent-Video-Card-Dock-p-1011222.html?rmmds=buy
With a PCIe to USB 3.1 enclosure http://www.dx.com/p/usb3-1-type-c-to-m2-key-b-ngff-ssd-hdd-enclosure-black-418463#.WA310Pl974Y
I have the Dell D2 8pin power supply 12V 18A, and the advantage of the Beast eGPU setting is I dont need to cut the cable and rewire it to ATX, so just plug in, pluging in the GPU, and delivered cable and I end up with eGPU over HDMI to PCIe (PCIe is so far I was able to find out the solution DELL uses on his Alien Ware computers, although on a proprietary solution)
Now I dont want to have my NUC open, with a PCIe cable pluged in for anything else than testing, so I like the idea of USB 3.1 or Thunderbolt solutions, so here is my thought, what if I would take the Beast V8 eGPU and instead of plugging it into the NUC I would plug it into a PCIe to USB 3.1 case:
Would that work?
I see several advantages over PCIe direct
Plug and unplug while PC runs
Its much safer than a open PC with a cable inserted
No need to redo the cable input from the Dell power supply
As well I see a disadvantage:
The PCIe to USB 3.1 might in fact be a USB 3.0 with a 3.1 connector and hence the speed would be reduced to USB 3.0, as well every reduction in its way will reduce the overall performance, just not sure by how much
So what are your thoughts?
BTW I own a reduction PCIe to USB 3.0 for my SDD drive:
https://www.amazon.com/gp/product/B00KQ4LNJC/?tag=theminutiae-20
would that work as well, I know the speed would be slow, but just to test it as a proof of concept
Please let me know, before i give it a try I for sure would first get some inputs, not to blow up my NUC
Would that work?
