Dual 240 rads - is it worth it?
lunr
I've seen a few builds using dual 240 rads but is it generally worth it at the end? I haven't found enough solid data to justify it. I've only found a few posts here and there saying there's little or no difference from a setup like a 92mm + 240mm.
I'm currently planning a loop. My plan is to stick a slim 240mm on the side with regular sized fans and a slim 120mm on the bottom with a slim fan. The rear isn't an option due to me putting a reservoir on the back.
