Hello everyone, great little community here!
Planning my first SFF build with an incoming M1 v6.1 - would appreciate if I could get some advice on the following 3 concerns:
- On the 2 intake slim Noctuas at the base of the case, does it require me to de-shroud the GPU? I will be using the EVGA 3080 XC3 and my preference is not to have to as I'm afraid I'd mess up the card. If so, should I skip the 2 fan placements?
- I have on order the EKWB 240 AIO Basic. Had thought to place a 92mm Noctua fan at rear of case - would this clash with the side mounting of the AIO radiator? If not, would intake or exhaust config work better for this rear fan?
- Planning to add on more mesh filters as my room gets pretty dusty and it seems Demcifilter filters are the popular choice. On their site, I see 2 options for side panels but not sure which is the one I should be getting: https://www.demcifilter.com/search?q=m1+v6.1
