Discussion DeskTop Mini x300 fan control?
MrJvr
27
Hey there.
So I have an X300 and I'm trying find some desktop fan control software?
Is there any native ASRock software available? I have a broken installation of AI Suite 3 which I'm struggling to remove and it's a work machine so I cant reinstall (would have been 10x faster though!).
Whats everyone out here doing for fan control or just using the bios?
MrJvr
27
You can 'manually' set a 4-5 position curve in the bios (@30 degrees, fan speed = 25%, @ 45 degrees, fan speed = 45% etc), however I'm looking for a utility that can be used within windows without having to reboot every time I want to tweak the fan curve...
I'm confident I could get speed fan working however it has it's drawbacks (ie much more setup, only effective after OS has loaded the application etc).
I do like to tinker a lot with various cooling solutions, overclocks/undervolts etc so it's something I end up adjusting a reasonable about...
Cheers.
