Quiet(er) 40mm fans???
royalba94
AVAENTUM SLEEVING
Apr 2, 2017
268
434
Avaentum.com
Hey everyone!
So I'm on the hunt for some quieter 40mm fans for my PC. The main fans I want to switch out are the ones that come installed on my IcyDock ToughArmor MB998SP-B enclosure.
I don't mind having to control them separately from the enclosure and I'm also open to possibly having an adapter 3D printed to a larger fan size if anyone thinks that'd be better, only issue with that would be designing ones that fit in my case.
Thanks for looking and I'm open to any and all suggestions! :)
7,732
Noctua's 10mm and 20mm thick 40mm fans are the only that I've come across that are somewhat acceptable.
royalba94
AVAENTUM SLEEVING
Apr 2, 2017
268
434
Avaentum.com
Thanks a bunch for the reply!
I kinda figured it'd end up being Noctua. Is there a noticeable difference between the 10mm and 20mm sizes? I'm guessing maybe the 20mm one is a bit quieter?
7,732
20mm pushes a lot more air, and the tone of the sound is less high pitch.
I'll be covering the 10 vs 20 in a review very very soon :)
Reactions: royalba94
