Deskmini 310 8700k build
changguangyu
82
56
Package Contents:
Chassis and Rear I/O are same as Deskmini110
changguangyu
82
56
Power adapter is AcBel ADC027, 120w, same as Deskmini 110.
Dimension is 150*65*36mm, 600g weight, Efficiency 89% @ 115/220Vac max. load
changguangyu
82
56
Have to ask: do you actually need a heatsink on the drive? What kind of loads are you subjecting it to? What temperatures are you seeing?Especially with it positioned right in the airflow path from the CPU cooler, one would think that thermal throttling would be a non-issue.
It's very useful. SSD will overheat frequently, and thin heatsink also not help much when copying large files.
Shrink Way Wielder
Jan 20, 2018
1,739
1,623
Hm, interesting. What brand/model is the SSD? I do have a (much!) larger case, but my 960 Evo lives behind the motherboard with very little access to air, no heatsink, and the only air intake in my case is through a radiator, but I've still never seen ti exceed 75C even when stress testing.
changguangyu
82
56
I'm using Samsung 970 Evo. I tried copy over 100G large files, there is throttling due to overheat.
Shrink Way Wielder
Jan 20, 2018
1,739
1,623
Well, if that's something you do often, I suppose you're one of those edge cases that actually might have need for an SSD heatsink then :)
HereToHelp
1. So the i7-8700k is recognized by the BIOS. What about the i7-8086k, do you know if it will be recognized by the BIOS?
2. What is the CPU fan speed set for in the BIOS?
