MOD BREAK: I split off the topic because it was derailing the Custom Projects & Cases topic it was posted in. Please continue here in a civil manner.
For purely decorative elements - such as the character line - what does it contribute? Does it fit with the rest of the design? What does it communicate to the user? What adjectives does it suggest? "Fast?" "Powerful?" "High-tech?" Is the message consistent with the rest of the design? Think about these things. If it's not adding anything of value - not communicating anything meaningful to the user - then why add it?
IMO trying to convey dynamic concepts like the adjectives above via simple cuts in sheet metal, in a way that doesn't look crude and amateurish, is next to impossible. You can do a lot more with stamping/forming sheet metal (as in automotive body panels, for example), but when you're limited to to basic cutting and bending, one really needs to be judicious in the styling department. Less is more.
Just my $0.02, FWIW.
I understand why you did it, I just don't think it's the right choice. "Design" isn't something that should be "added;" rather, you want to think about your design holistically. What is your design saying? Does it communicate its function and purpose well to the user? How does each element fit into the whole?Well, we've designed that to add some style/character to the otherwise rough and boring vent area and the whole side panel in the first Sentry.
