I just ordered parts off Amazon, so I will begin the build log. I've been sitting on the fence, doing research and measuring things for quite a while - time to start the thread!
My current computer was a SFF beast back in its day - Is tarted off with a Shuttle SX48P2 , added in an Intel C2D E8400, 8GB of ram, an upgraded Shuttle 450W SFF PSU, and last of all, a PowerColor Radeon 4870. I packed all of this into a Pelican Case along with a Shuttle thin 19" monitor and took it over most of the East Coast on week long business trips. Now, I am starting to feel the urge to upgrade and I am looking to make something I can take with me on my next Marine Corps deployment.
1) Parts to Date:
Computer
Intel i6600K Processor
GA-Z170N ITX MB
Corsair Vengeance LPX 16GB DDR4 3000MHz (PC4-24000)
Noctua NH-L9I
Intel 80gb SSD - already currently own, plan to recycle
Case
Pelican 1490 Case
Pelican 1490 Panel Frame Kit
The measurements for the 1490 Pelican case are:
EXTERIOR (L X W X D)
19.87" x 13.93" x 4.68" (50.5 x 35.4 x 11.9 cm)
INTERIOR (L X W X D)
17.75" x 11.37" x 4.12" (45.1 x 28.9 x 10.5 cm)
Now, I know this doesn't look extremely challenging, but I plan to build in just the bottom half of the Pelican Case - reserving the lid for a possible monitor install and peripheral storage. The case's bottom measurements are:
17.75" x 11.37" x 2.62" (451mm x 289mm x 67mm) [or 8.73 Liters] - actually a little less than that, because the panel frame kit (will let me use a metal plate in between the top and bottom lid) will eat up a lot of that space. I am estimating an overall height for the build of 61.5mm.
I have done some initial mockups with cardboard and a graphics card I borrowed from a friend. See below:
I will be waiting for the upcoming Pascale release before I buy a graphics card, but the current Radeo 7970 in there is a 'worst case' scenario - I will be aiming for something like the Nvidia 970 GTX in terms of size/price/performance. I've also been looking into riser cables and estimate I will need about a 250mm cable.
I am up on the air in terms of PSU at the moment. I did the original mockups with an SFX sized PSU in the case, but I think that it will be about 2mm too tall for the top panel (an aluminum plate I plan on either making myself or ordering through DataPro). This leaves me with several choices - cutting a PSU sized hole in the panel, modding the PSU to be about 2mm shorter (possibly replacing the fan at the same time with a 120mm x 12mm fan?) or going with a Flex ATX PSU. I am hesitant to go with a Flex ATX PSU because I have heard they are super loud, and the last thing my future room mate on deployment wants is a jet engine cycling up when I try and watch a movie. I have considered and discarded an HDPLEX 250W board with a Dell/HP brick mainly for budget reasons - all the components except for the graphics card are on a budget of $650 (I already owned the pelican case and SSD - purchasing everything else).
Other issues to be addressed as parts arrive: static buildup, grounding, shock mounts, attaching the motherboard to the case without drilling through anything, mounting a laptop LCD screen to the lid...
It will be a wild ride!
1) Parts to Date:
Computer
GA-Z170N ITX MB
Noctua NH-L9I
Case
Pelican 1490 Case
