Hi everyone, I am new in the SFF world. So be kind to me.
It has been some month now that I discovered that Small Form Factors could handle high-end gaming configurations, and so I wanted to try the experience.
I ve already build like 3-4 normal configurations for me, family or friends, so I consider myself not a total beginner. But this Dan A4, damn, has taken me already some hours.
I came to present my build. It is not finished yet ( i am waiting for the SSD M.2), but I ve been able to go into the BIOS and begin to custom my fan curves, CPU voltage, ... and check the idle temps
Here is my setup, then I will say about my concern. Sorry if my english is not perfect, you have a baguette guy in front of you. ^^
Now let's talk about this AIO Asetek 645LT. (For information - It is my first time mounting a CPU watercooling)
First thing I ve struggled to get everything inside the case clearly because of the Asetek. I feel like it is taking a big place for nothing.
Secondly, the temps. Only being in the BIOS, my CPU core already reach 60-65C. All my other temps are around 40-45C.
That is my concern. Do you think I ve been doing something wrong? I dont think the thermal paste spreading was badly done (as said, I already build several PC already without issues).
The air going out under the case is hot as f**k and I am not even playing yet.
I am really dubitated about the efficiency of an AIO cooling inside this kind of case. The fan can barely take air inside the case (PSU cable are just above). The hot water has not time to cool that is already going back into the CPU. Not a good first experience for me right now with this AIO.
I ve read other topic such as this one :my-first-itx-build-dan-a4-sfx-v4-1 in which he cool his CPU with the Alpenföhn Black Ridge. Do you think i might have better results with this one (and more free space also) ?
Pictures will come soon, I not at home right now.
Thank you for reading me, see you.
Case: Dan A4 v4.1
Motherboard: MSI MPG B550I GAMING EDGE WIFI MINI ITX
Cooling: Noctua NF-A9x14 HS-PWM chromax.Black (as Intake pulling air into the case - located under the MoBo)
M.2 Cooling: included in the MoBo
CPU: AMD Ryzen 7 5800X 3.8 GHz (Base clock 1.430Ghz with an -0.1 offset voltage)
Thermal paste: Thermal Grizzly - Kryonaut
Cooling: AIO Asetek 645LT 92mm + Noctua NF-A9x14 HS-PWM fan (Exhausting air outside the case - located below the PSU)
Memory: Gigabyte Designare 64 Go (2 x 32 Go) DDR4 3200 MHz CL16 (Mobo natively maxed at 2600MHz so I activated XMP (D.O.C.P) to change clock at 3200MHz)
GPU: Gigabyte AMD Radeon RX 6800
Storage: AORUS NVMe Gen4 SSD 2TB
PSU: Corsair SF750 80PLUS Platinum
