Dan a4 v4.1 Would a nzxt g12 with asetek 645 lt fit?
BerGO
Hello,
my question is if i can fit a nzxtg12 in the dan a4 v4.1 with the asetek 645lt?
would it be too wide?
thanks for ur help
dondan
DAN Cases
1,871
7,946
You have only space for a dual slot GPU and if you install the G12 you will have a 2.5-2.75 Slot GPU. Even if you cut the G12 the pump will be too high. If you like to watercool the GPU on a 92 radiator. Get the Alphacool GPX water block that includes a silent pump and mount a to a after market 92mm radiator.
Reactions: BerGO
