First builder (people always seem to highlight that for some reason) already tackling hard mode here. Read quite much on the topic since it is truly fascinating, while still consider myself a layman, especially since I have no actual building experience.
So I've been thinking about this idea of doing a custom loop with soft black tubes in this case as it seems that I'm gonna be having my hands on a Dan A4 in the near future. However I soon came to realize that if I really want to make a well optimized solution and not just go with a H60 for example (which would be probably fine), the parts are hard to come by and my options are very limited. We'll see about the tubing and fittings, but what I know is that I'm planning on using Alphacool's Eisbaer LT (solo) for the pump. It's seemingly the same as the Kelvin from Fractal Design and kinda the only that I found suitable and not shoddy in quality. Also seen fabio using it in a build displayed on this page, his feedback from personal experience would be welcome.
As for the radiator setup, there are 2 options and this is where I kindly ask the help of the good people frequenting this forum.
I can either go with a 30mm rad paired with a 12mm fan setup using the Alphacool NexXxoS ST30 Full Copper V.2 a very promising thick full copper component that would leave me with an extremely thin 12mm fan that's the Scythe Slip Stream. Supposedly best rad with the weakest fan that's perhaps more suitable for improving airflow in cases rather than be paired with a radiator, but it could work.
Or focus on the fans being better by getting the reliable and silent Noctua NF-A12x15 PWM (chromax) and combine it with either the Magicool G2 Slim Radiator 16 FPI (27mm), or try the XSPC TX120 Ultrathin Radiator (only 20mm!) and still have 7mm of clearance. These radiators are supposed to be from copper and brass as well.
As a heads up, please kindly save the replies mentioning that 120mm aio's have no point suggesting me to either cram a 92mm asetek under the psu or go air cooling instead I would really like to execute this build with the 120mm liquid cooling setup allowing me to utilize cpu's with better performance while sill use a decent itx gpu (as even my games are not that gpu heavy). I also think that this is the most efficent use of space inside this particular case.
Thanks in advance,
Richard
Thanks in advance,
Richard
