Hello,
First of all, I'm very new to this forum so hi there!
I've build several PC's and have been tinkering with a neat small ITX build focused on a water cooled loop.
So i launched SketchUp (i'm not very good with it) and started importing some models i could find and place them to my liking.
I quickly figured out that doing a full loop placing the resevoir and pump was a pain. There's not alot of space and i wanted to make the case as small as posible.
So i figured i went with a CPU heatsink / pump combo. Then there was the resevoir and tubing. Eventually i figured perhaps milling out a custom build res might be an option and saw some room on the 2nd GPU slot. Most GPU's are 2 slots but with a Waterblock on it the 2nd slot space is not utilized.
Then Designing the resevoir i've found it easier to make the coolant go from CPU pump to GPU through the res, from the GPU to the Radiator, from the radiator into the Resevoir and from the resevoir into the CPU pump.
As a refference i've taken the following parts:
GTX 1080 Ti at 298mm with waterblock on it.
a general ITX motherboard
PSU : SF600 SFX
M.2 1TB drive directly on motherboard.
Apogee Drive II CPU block / pump
Custom designed Resevoir (Resevoir compartment is roughly 500ml)
General fittings from bitspower
16mm Rigid tubin
Things i would like to include:
-Dust filters and vented side's/top (magnetic perhaps)
Things i still need to do:
-Fine tune the placing of components to leave room for
1. Cable management
2. Perhaps a 2.5" SSD
-Map out Cables (including PSU power relocation)
-Design mouting brackets/plates for all components
-Design Case (including the front and power on switch)
I hope to hear your toughts on the layout and if it is feasable!
Any suggestions and toughts are welcome.
Kind regards,
Crabz
Below are 2 photo's the rest is in a Imgur album : Concept 9L ITX Case
PSU : SF600 SFX
16mm Rigid tubin
1. Cable management
Kind regards,
Crabz
