Hey guys! I'm recently working on my water cooling S4M build.
I need a custom heatsink for my GPU, but making one from scratch will be crazy expensive, so I'm looking a method to machine an exist aftermarket heatsink.
My idea is, by using expanding spray foam, I can fill in the gaps between the fins. When the foam is hardened I should be able to just mill the shape I want out. After CNC, I can just dissolve the foam with acetone. But I've never really had any experience with CNC so I'm not sure if this idea will work or not...
Any help will be appreciated!
