Log CM NR200P DUAL 280MM
FiftyFifty
66
126
New to the forum and wanted to show off my old build. Hope you enjoy.
  • Cooler Master NR200P Black
  • AMD Ryzen 7 3700X
  • Asus ROG Strix X470i Gaming
  • Gigabyte GTX 1080 Xtreme + Bykski waterblock
  • Corsair 2x8GB DDR4 3200Mhz CL16
  • WD Black SN750 1TB M2 NVMe SSD
  • Crucial P2 1TB M2 NVMe SSD
  • Corsair SF600 600W PSU
  • Barrow CPU Water Block Combo
  • Alphacool 13/10 PVC Transparent tubing
  • EK-CryoFuel Clear
  • EK-Torque Fittings 13/10 Nickel
  • Aquacomputer sensor
  • 2 x Corsair Hydro X Radiator XR5 280mm
  • 4 x Arctic P14 PWM 140mm
  • 2 x Arctic P12 PWM 120mm
  • 2 x Mini Antennas 5cm
zk2004mb
58
32
No sorry i have not.
I strongly advise you test it. I did a triple rad build in nr200. 1x 280gts, 2x TX240.
One 18w DDC pump is not strong enough. I got only 0.7~0.8 GPM at max speed and it's very noisy.
I end up with two 18W ddc pump, now I can reach 1.2GPM at max. 0.75GPM at quiet.
Reactions: thelaughingman
FiftyFifty
66
126
Thanks for the info. My water temp maxed out at 36 celcius with relative slow fan rpm so i have not had any reason to worry.
