Stalled Catz C-1 (5L), C-SFX (10L) and C-WS (15L)
amitoza
93
258
C-1 without unibody
screws will be black in final version.
with unibody
D
Deleted member 18
Guest
I like that you could even use a passively cooled GPU thanks to orientatio of the GPU slot. Nice work!
CC Ricers
2,235
2,558
Is it possible to have a gloss finish on the unibody paint? Gloss white would look amazing.
Also, what CPU heatsink are you using with the demo build in the C-1?
robbee
890
1,408
That's looking super clean!
Am I the only one who thinks of this when looking at the SFX unit btw?
amitoza
93
258
Veery old Steel prototype - white gloss.
Its raijintek Zelos with prolimatech 120mm.
Reactions: CC Ricers
amitoza
93
258
Temp chart for Catz C1 horizontal OCCT test.
CPU i3 6100, cooler - raijintek Zelos with prolimatech slim 120mm with low noise adapter
GPU - GTX960 gigabyte itx with zelos fan.
On minimum - non-audible from 10cm, on full very quite but audible.
bledha
307
268
Render of new project. Pre alpha version.
Was 5L... 10L... so now is 15L and space for 170mm cooler.
Yes, wow. This is quite the looker. I know it is still in project mode, but any idea of dimensions as it is now?
