Second batch will be ready on Tuesday, but tomorrow I'll go for easter to family and I'll be back on Friday.@amitoza Any word on the second batch of cases? Also, do you, or anyone else, have a suggestion for which heatsink to go with if I'm using Intel?
i3? i5? i7? I like raijintek zelos - very quiet and cheap.
Its raijintek Zelos with prolimatech 120mm.
I used prolimatech because Zelos fan have red frameI see you put a 120mm fan on it here, did you have to do any mods to fit it on? And do you have any idea how it compares to a noctua L9i? I'm not too worried about spending an extra $20.
@bledha Got any pics?
I've been eying your cases for a while now and I love the design of the C-1.
I'm wondering what the chances are that you will create a modified version of your C-1 (or C-2) case that will be a little longer so it can fit the hdplex 300 DC-ATX + hdplex 300 AC-DC (just got an email that it will be available in a couple days).
The sizes are:
* 300W AC-DC: 62 x 151.4 with a height of 41
* 300W DC-ATX: 50 x 150 x 25
The width of the C-1 should be fine to mount both of them on the front. The height is also enough.
But we would probably need an inner case length of closer to 220mm to fit an ITX length graphics card + the ac-dc.
I have the same gfx, and I'm hoping you are right.. That would be pretty awesomeI have the EVGA GTX 1060 6GB and I think I will be able the fit the internal AC-DC converter.
Received the case and it's beautiful. Unfortunately I can't build in it until summer as I'm away from home
I bought a sintech extender and will probably get a 300W HDPlex, unless there are cheaper alternatives to that.
Yes, each case will get plate with number.
Ah should have taken some before I left. Anyway, I think the black one here from this post is mine :-)@Kagemand : Pics?
Yeah budget is also an issue for me. Already have a perfectly working r9 290, but it won't fit the new case, of course! And I don't really feel like side grading to a GTX 1060...I know that feel. I haven't built a PC since 2011 (it's long since been gutted and sold) The Mrs. has given permission to let me build a PC again but looks like a Fall effort at the earliest. All I can do is lust after the hardware in these forums until then...
