I recently received an order to build two cases according to the client's requirements. Perhaps someone has thought about this option or is looking for such a case, you can write to me and I can do something similar for you.
Size: 5.7L (302mm x 175mm x 108mm)
Material: Steel or Aluminum
Weight: 1kg
COMPATIBILITY:
MB: mini-ITX (170x170mm)
GPU: up to 280mm long (up to 42mm thick)
Cooler: up to 45 mm high
RAM: up to 52 mm high
PSU: SFX / SFX-L
FAN: 1x 92mm
![Small blue diamond :small_blue_diamond: 🔹](https://cdn.jsdelivr.net/joypixels/assets/6.0/png/unicode/64/1f539.png)
Weight: 1kg
PSU: SFX / SFX-L
FAN: 1x 92mm
