Case design and expensive PC parts
chx
555
287
When you design a case, how do you get parts to check for dimensions? Getting a large TDP CPU + MB + GPU (multiple, even) is more expensive than getting a case designed and prototyped... Buy and resell? Buy broken parts from eBay so you can check for physical fit?
SumGhai
147
175
I disagree that getting components is more expensive than getting a case designed. If you're just checking for physical dimensions, you don't need to spend much to get what you need.
A super cheapo last-gen mobo can be had for less than $50, plus an intel box cooler just for fitment testing. As for GPU, again you can go super cheap and get cheap $10 network cards. If you want to, you can get a super last gen GPU. The physical standards don't change just because something is higher end. Overheight graphics card mockups can be made with network cards and cardboard. If you're feeling fancy, then grab a GTX 650 ti, some tape, and cardboard; and as a bonus you'll have a 650ti that you can actually use.
Reactions: el01 and owliwar
Beardedswede
191
158
Designing case and protyping it is very exspensive and long process if you are doing it as a consumer product to sell so I'm not sure what you mean .
But you are correct they probbaly dont buy every motherboard,cooler and GPU in the world.but they probably use their friends and familys cards ,maybe has contact with a repairshop or just electric store to go and take measurments. And they just take the measurements from the manufacturers website
Reactions: el01
Windfall
2,117
1,584
There are accurate 3d models you can use in CAD.
chx
555
287
Well, for example risers and their cables when running in a tight place. All sorts of cables...
Choidebu
"Banned"
Aug 16, 2017
1,198
1,205
Perth
Also most started off while building pcs for friends and families, maybe even as a side business. You tend to come across a lot of different hardware that way.
Reactions: el01
owliwar
586
1,082
São Paulo, SP - Brazil
I seccond the 3d model approach. Its a bit hard here to get used hardware at really decent prices (only high end part get a good discount after a couple of years) so I mostly double and tripple check everything in the cad program. for that I Recommend our resources section and grabcad.com
One thing that I did a lot and helped was exporting my 3d model to .stl and importing in sketchup, since sketchup community warehouse is quite large compared to grab cad, but not all models are precise so thats also a bonus point for our resource area here in the forum.
Reactions: el01
Damascus
554
395
As someone who is currently making a physical prototype for an extremely high end rig/case, I have some input. I got the mobo used for $20, psu for $25 and the riser was $3. The frame itself has run me $20 in materials, and about $100 in tools (hacksaw, sawblades, drill, bits, rivet gun and rivets) making it easily twice as expensive as the base components I used for testing. When all is said and done I'll be dropping a grand in components into it, but for testing you need basically nothing
Frame time
Reactions: owliwar and el01
el01
770
588
Front Range, CO
Well, then you get into an area of manfacturing and product feasibility. If you're going to use a metric ton of risers, perhaps it would not be an effective design for the masses?
My logic when designing things (since I don't own SFX power supplies, HDPlex, nor many components) is to think properly about the layout and usually just adding extra tolerances. I usually just make things slightly larger than they should be in case bad things happen.
Reactions: Damascus
cleveland
455
242
Brasil
Frame time
You got me completely erect (no homo) with those pics... i'm starving to see the rest of the job done.
Damascus
554
395
I've got all my components, only thing that's holding me up at this point is the gpu block/pump. I currently plan on using an asetek gen one block, but the pump is atrocious :/ I'm probably going to see about getting one of alphacools universal dc-lt gpu blocks for the 1080.
Oh, and a res. I wanted to get it from performance pcs but the shipping is nuts as always
Reactions: cleveland
