@Choidebu
Pick a tool to learn that reads .stl files, then lookup how to 'export' 'surfaces' / 'faces' to svg.
I basically had to learn it when I was trying to export the parametric case to 2D and failed miserably.
Then you'll still have to decide how to join them and your panel's width, whether or not to have them flush at the join (means you'll have to shave the framing panel's width out).
I was planning to use this specific "
L-Bolt" for a first try, anyway, I don't know If It'll work until I test it, though.
This still doesn't include internal panels and how to mount them...
Which internal panels are you referring?
At which point you'll just design a whole new case on your own ^_^
That's what I was trying to avoid, but It seems to be the only way. (This not mean to be a lazy thought, It's just I'm busy at this moment but I'll refuse to use this as an excuse to not try.)
Thank you for all your considerations.
@VELKASE Michael
If you know how to use the program you plan on using, then not too difficult. It's definitely possible. You'll also have to think of a way to implement standoffs for the motherboard if you want them. For example, cutting a hole in the acrylic and installing a regular standoff with a nut and washer on the other side.
That was my first thought on how to implement the standoffs and "hold them", I think It'll work well, but thank you for your consideration.
The only way to find out exactly how difficult it will be is to try
That's right.
@Choidebu
You can buy threaded insert meant to be heat installed in plastics, see
https://www.pemnet.com/fastening-products/si-inserts-for-plastic/. Maybe your local hardware store have some variant of them. I know mine does. DIYing these is easy enough: Predrill a hole, lay it on top, heat and push with soldering iron until flush. After that just regular standoffs.
I haven't seen it in any near local suppliers and I just have the regular standoffs, but I guess I can find a way to do it, "improvise".
The original poster of the parametric case has advised it in his post, which is a solid advice!
Anyway, thank you for your consideration!
If people tell you it's easy, you'd probably do it. If people tell you it's hard, you'd not do it and prob wondered your whole life if it is that hard.
Tell you what - if all you have to lose is your time why not do it and see for yourself?
My concerns were not mean to be a lazy thought, on the contrary, I was just trying to understand If my idea was viable and not something "catastrophic", I mean, for me seemed viable, but I thought It would be better to ask, because someone could have already attempted and say If would "makeable".
(I know, history has already proved that even when someone says something is impossible, another person proves that It was wrong as the person has done it. But, as we are in a "niche community", I knew my idea was already considered and I was questioning the viability.)
Anyway, thank you for the encouragement.
Both of you,
@VELKASE Michael and
@Choidebu, thank you for all the patient, help and attention you have gave me.
I'm sorry for all the inconvenience and the time I made you spend with my concerns.
Have a wonderful time!
