Hello,
I'm in the process of building a computer inside an Original Xbox case to use as an emulation HTPC, it's been done before so I know its possible, however one thing all of them have in common is that they never use a 3.5" HDD, probably due to its size.
This is what the layout is looking like at the moment if I was to get a 190mm FlexATX PSU (150mm would be to the line that can barely be seen):
http://i.imgur.com/DQ04uhI.jpg
My plan is to also have a mini 1050ti sitting on top of the HDD with a PCIE riser.
I don't think I'll have enough clearance to fit the HDD and also the Graphics card as I plan to raise the motherboard off the base slightly with standoffs, then a little clearance for the PCIE slot, followed by the HDD then finally the Graphics Card.
Anyways, I have a couple questions:
Are there any smaller form factor Motherboards that I can also use a graphics card with?
Do you think I could get away with using the picoPSU-160-XT + 192W Adapter ( http://www.mini-box.com/picoPSU-160-XT-192W-Adapter-Power-Kit )? PC Part Picker shows a max of around 250w but I don't know how accurate that is.
PC Part Picker:
https://uk.pcpartpicker.com/list/jcBfgL
No components other than the HDD and cooler has been purchased, as that is all I have from a previous build, so I'd be up for changing stuff around if needed.
Thanks in advance for your help!
Edit: I might have found a way to have the HDD slightly above the two sticks of RAM which should give me the clearance needed for a FlexATX PSU. Anyone got any good recommendations, something preferably quiet! Thanks
PC Part Picker:
