I found this board that looks similar to the other Supermicro, but it comes with a fan...
S suspenceiskillinu Efficiency Noob Original poster Mar 30, 2016 7 0 Apr 8, 2016 #21 I found this board that looks similar to the other Supermicro, but it comes with a fan...
iFreilicht FlexATX Authority Feb 28, 2015 3,243 2,357 freilite.com Apr 8, 2016 #22 suspenceiskillinu said: I found this board that looks similar to the other Supermicro, but it comes with a fan... Click to expand... There are a lot of different versions of this board, they also vary in the amount of LAN connectors and the CPU that's being used. You can take a look in the manual.
GuilleAcoustic Chief Procrastination Officer Moderator LOSIAS minecraft.sff.network Jun 29, 2015 2,606 3,851 guilleacoustic.wordpress.com Apr 8, 2016 #23 iFreilicht said: There are a lot of different versions of this board, they also vary in the amount of LAN connectors and the CPU that's being used. You can take a look in the manual. Click to expand... Exactly. The one you linked has dual 1Gb and dual 10Gb connectors.
