BIG POST BELOW
Hello everyone,
My name is Rick and I'm new to this forum.
I was tired of using my laptop, which is getting old also, so I've decided to go on with an SFF build next.
Found this forum by looking at Tekeverything youtube channel. The guy (Jay I think) did some serious reviews and I found it really interesting, so here I am.
I've built many PCs in my life but this is the 1st one I'm gonna build in a small form factor.
I'm gonna use it essentially for gaming and some webbrowsing. I want to build something that will be functionnal for the next 3-4 years. I'd like to be mobile, and to be able to bring it anywhere by putting it in a bag.
I'm still unsure about certain components, that's why I came to ask you guys a few questions or advices to make the best choice for that config.
For now it looks like this: https://ca.pcpartpicker.com/list/sFCZTH
It looks a bit expensive, but I'm not sure if I'll be able to lower the price much, as I'd like quite a powerful gaming rig and I need to get myself a screen.
What's your opinion on that case, I've read this thread and I'll keep an eye on it, as I'm going to build something quite similar.
I'll see if I can get an extra lid as mentionned in the above thread, as I'll be cutting holes in it for vent.
The upcoming intel platform on the other hand, is quite expensive but probably a bit more futureproof as the i9s will fit on the same socket. That being said SFF motherboards are not even available yet, and will likely be pricey.
Do you guys have any advice/ recommandation?
I mean, is there any kind of ram we should prefer when building up a SFF case?
I heard about low profile ram, is that something I should consider?
Is this small enough?
So I'll try to fit the best GPU I can in there. From what I found this will be likely be a 1060, unless there are any other alternative that are not much more expensive.
I've seen some 1070 mini but they're a bit pricey. 1080mini is out of the question as it is too long. I don't wanna cut the back of the case or the GPU heatsink itself.
According to my future build on PC part picker, such system will require 250W of power.
I would prefer to avoid adding anything else that generate too much heat inside the case.
What would be the best solution for me? HDPlex + Power brick? (300W?)
What are exactly the custom solutions that G-Unique offers?
Is a PicoPSU worth getting and power sufficient for such configuration?
According to the dimensions and space left in the case, what should I get and what shouldn't I?
I know that's a big one, but I want to make sure about my build before I start actually buying the stuff.
Once I'll get everything defined correctly and some of my questions answered, I'll start buying the components, and I will create a new thread to show how my config is building up bit by bits.
As you may have understood, I'm new to SFF building, and therefore open to any advices.
Well, I thank you all for your help and time.
Rick0
Hello everyone,
- CASE
- CPU / MOBO
- AM4 mobo / Ryzen7
- X299 2066 Mobo / I7 7740X processor
- RAM
- GPU
- Power Supply
Rick0
