To avoid making this as much of a wall of text (and pictures!) as possible, I'll be splitting this into a couple of posts. Tl;dr: I want feedback on my ideas for building what's in the title, both on my proposed cooler and how to build a case. Post 1 will focus on the idea/use case and cooler.
I've been playing with an idea for an HTPC build for at least a year now (it's still quite a while away from even potentially being realized, so no rush!), but I've decided I need some feedback/help in going forward, as I'm a bit stuck. The situation is this: in time, I want to move my current NAS/HTPC build (in a Fractal Node 304) out of the living room to full NAS duty and build a small, silent, light gaming-capable HTPC. A GPU is out of the question both due to price, utility (I really don't need it, the actual amount of gaming done on this will be small, and I can use Steam in-home streaming for anything demanding), size, and noise (vs. size, at least). I'm quite sensitive to high-pitched noise, so small fans are a big no-no. Its main use will be video playback, streamed or played off the NAS. It's also worth mentioning that I'm not willing/able to spend a fortune on this, and saving money/not spending too much is definitely a factor. Otherwise I'd just buy an S4 mini or something
For now, with what's available, the Ryzen APUs look like a good fit. I'll likely not be buying/building anything until the next generation is out, though. Choosing between the R3 and R5 (or their next-gen equivalents) is tricky, though. The performance difference isn't huge, and the price/perf favors the R3, but I like to keep my hardware for as long as possible, so I like to buy as fast as I can to make it last. As such, the additional $60-ish might be acceptable. Other specs are really not interesting; it'll have a suitable motherboard (the ASRock X470 ITX looks nice currently, but if something cheaper comes along with the right features, I'll take it), some RAM and an SSD. For a PSU, I've been going back and forth but for now I've landed on getting the HDPlex 160W AC-DC+DC-DC combo pack - it seems like good quality and a decent price, even if the ">80% Efficiency" is sad compared to (impossible to obtain in Norway without egregious import taxes) Mean Well EPP-series.
Now to the interesting part: the cooling. I have two old Arctic Accelero S1 GPU coolers lying around from back when I had Crossfire Radeon 4850s ten or so years ago.
Being rated for <150W GPUs passively, I'm thinking one of these should be able to keep an overclocked 65W APU (pulling 100-120 from what I've heard) cool if I put a 140mm fan on it, no? The S1 is a rather large heatsink with four hefty heatpipes and a copper base, after all. I also have a Noctua NF-A14 FLX lying around which should be an excellent companion. The cooler is large, about 22cm wide and 14cm tall, so (depending on CPU socket placement) it'll overhang the sides of the motherboard, and of course block the PCIe slot (not that I was going to use it, except maybe for one of those Silverstone remote power buttons). It'll also require a case "big" enough to fit it alongside the motherboard, with a 140x25mm fan stacked on top, plus the PSU and some spare room for a power switch and USB ports (I'm estimating around 25x25x12-13cm including wood or similar case panels). Picture is the cooler "test fit" on my Biostar X370GTN inside of my NZXT H200i (couldn't be bothered to pull the motherboard), with the cold plate centered on the CPU. It fit, but not with much room to spare.
The first issue with this is of course clearance, as the cooler is designed to lie almost flush over a GPU. Since I have two and no use for these otherwise, I decided I could sacrifice one for experimentation's sake. But lo and behold, the heatpipes bent quite easily. RAM clearance is fine over my TridentZ DIMMs, which makes me hope clearance is okay for the DC-DC PSU too. It looks weird, and the bend will affect airflow, but I think I can live with that. This turns into quite a tall cooler, though, especially with a 25mm thick fan on top. Some very rough measurements place it at around 7cm from the motherboard. With lower profile RAM I could bend it down quite a bit, but that would likely require snipping out some fins to clear the plug-in PSU (hopefully I wouldn't have to bend a heatpipe out of the way, that would be tricky).
I'd have to fabricate some sort of mounting mechanism to fit into the am4 backplate, but that should be doable, even with my limited skills and resources in terms of metalworking. My thinking for now is a rather simple metal rectangle that I can screw through into the threaded holes on the cooler's mount (see below), and some holes further out corresponding to the AM4 mounting holes where I can put a bolt or threaded rod and nut through. This ought to make for a secure mount, at least.
The cold plate is smaller than an AM4 heatspreader at 30x30mm, but I'm hoping that will be enough.
The cooler can also be mounted "backwards", by the way, at least on the Biostar board. Might alleviate any PSU clearance issues, but it would make plugging in CPU power, front panel audio and anything else close to the rear I/O a pain without removing the cooler. It could also interfere with any thick case material surrounding the rear I/O, but I can of course remove the black plastic shield on top of the cooler.
So: is this feasible? Do you think it would work for cooling an overclocked R5-2400G (and provide sufficient airflow for everything else in the case, including the PSU)?
