For the SFF build that I am working on I plan to make my own case for it. The general plan is a case that supports the HDPlex 400W system internally with the C14 plug along with an ITX board and a mini version graphics card. This is just a personal, one off project (hence the 1 of 1 name).
I haven't used any CAD software but i wanted to have a play around with the system configuration and make sure that it could all fit and work together. At this stage I am pretty happy with the overall design and the only two points that i want play around with a bit more are the ventilation holes on the back of the case and the GPU mounting.
One of the features that I wanted in the case was the ability to change how it looks if i ever got tired of it. The front of the case has space for a 2mm (to sit flush with the top and bottom panels) insert to be attached. This will most likely be the same material and finish as the top and bottom panels, but I like to have the option there if i want it.
Detailed Specifications:
Exterior Dimensions (L x W x D): 392mm x 234 x 68mm
Volume: 6.3L
Max GPU Length: 225mm
Max GPU Height: 130mm
Max CPU Cooler Height: 45mm
Power Supply: HDPlex 400W AC-DC
Volume: 6.3L
