Cooling Best Low-Profile CPU Cooler on the Market?
Thehack
Mar 6, 2016
2,813
3,676
J-hackcompany.com
AR05 is a worse cooler. It's only worth it if you're building something that requires less than 50W and penny pinching.
You probably can't do LP53 parallel to RAM. You can try removing and or replacing the VRM with aftermarket heatsinks. Those heat sinks aren't actually that functional. Real heatsinks have high surface area to volume ratio.
You should wait for DAN premium cpu cooler that he will release. Might be what you want.
ZeroPucks
25
Thank you for the suggestions. I'd really like to hang onto my i7-7700K, but I'm not sure if the NH-L9i can handle it even at stock clocks. The DAN cooler looks intriguing, and I also saw that the copper C7 may be releasing soon and that a fan mod might solve the current sound issues.
Speaking of that fan mod, any relation to the maker of this 3D-printed fan adapter? https://www.shapeways.com/product/LSP757C2L/cryorig-c7-92mm-fan-adapter?optionId=62655969
Thehack
Mar 6, 2016
2,813
3,676
J-hackcompany.com
There is no reason to get rid of it. You can always limit the clocks and try as deep of an undervolt as you can.
Yes. I am the designer of that bracket. It won't help you with the atrocious turbulence inside the case, but it'll help increase the quality of the fan. It does add a bit of height, I believe 1mm so it becomes 48mm. Small zip ties will do the same job, but my adapter help make it look clean.
The DAN cooler will be possible to place the fan under the fins, thus resolving the turbulence issue.
ZeroPucks
25
I see. Thank you for clarifying the turbulence issue and for your further suggestions.
EDIT: Here's an interesting picture I found on [H]ardForum. A user photographed the LP53 heat sink with a Noctua fan (which looks like it's being tied down with copper wires) on an ASRock z270 itx motherboard. The layout of the z270 looks very similar to the z170 I have, and the fins are parallel to the RAM slots as I was hoping. https://hardforum.com/threads/sentr...case-project.1832126/page-118#post-1043127724
Thehack
Mar 6, 2016
2,813
3,676
J-hackcompany.com
Looks like not a mm to spare. Worth a try :)
palsystem
Hi. Regarding lp53. I bought i7 8700k and a4 sfx v1 case. What is the best fan to attach it to this cooler? Can I go for 140mm and would it be more efficient? System is built on ashs mini itx z370 motherboard. Thanks
Thehack
Mar 6, 2016
2,813
3,676
J-hackcompany.com
Noctua nf a9x14. You don't want to use a bigger fan because then the dead zone would be too over the fins.
palsystem
I'm planning an 8700k build using a Dan case clone I have coming from Taobao. I plan on getting an Asus ROG STRIX Z370I, however, I just learned the LP53 I have coming will not clear that boards VRM heatsink. Is the Cryorig C7 my next best option?
hi. Im just learning the same after clicked buy. so u sayin that vrm sink is obstructing the lp53? how much? can u bend or cut bit of both to fit it?
dumplinknet
364
168
Gotta remove the io and the top hestsheak. Also maybe the first ram module's hest spreader .
Use tiny, individual heatsinks for the vrm.
ondert
348
164
Bologna
Do you think Zalman CNPS2X is enough to cool down i5-8400? Or is there any better options within 1U coolers? I don't mean those hair dryers with 10,000 rpm fan.
IntoxicatedPuma
Customizer of Titles
992
1,272
Northwest Arkansas
Here is a great roundup of some of the best low profile CPU coolers for both Intel and AMD sockets https://graphicscardhub.com/best-low-profile-cpu-cooler/
It would help to have more data to back up the listings and show how they compare with each other. It sort of looks like just a big list of specs and stock pictures for each one. Also I'm a little skeptical because it says the AR06 specifically has difficulty installing, but I find it to be one of the easiest to install from that list. It's about the same as the Noctua NH-L9i.
Reactions: Kmpkt
NickIrwin
May 23, 2018
Some important questions I want to ask before giving my recommendation for the best Low Profile Cpu Cooler in the market.
1) Which CPU cooler you are currently using in your PC?
2) Do you have any plans to do overclocking with your PC?
3) What is the height limit of the case you are currently using?
After you answer my questions, if you are not planning to play with overclocking then Zelos is probably one of the in budget option for you. I don't like Popular noctua nh-I9i for one reason and that is it is not suitable for many processors.
You can also refer to this glinkster guy who writes amazing reviews and totally a gaming freak. https://www.glinkster.com/best-low-profile-cpu-coolers/
The Zelos which I am recommending you is nice solid speed cooler and it also doesn't make any noise while running. If you have anything to ask, feel free to comemnt. I am happy to help you.
Thehack
Mar 6, 2016
2,813
3,676
J-hackcompany.com
Yeah that link is crap. No measurements, no real comparison. Just affiliate farming using SEO summaries.
MarcParis
Apr 1, 2016
3,930
3,085
FRANCE
Well...at the end nh-l12S is really good and nh-l9i is also best for constraint area....nothing new..;)
Now for intel/am3, samuel 17 cpu cooler is really good too.
However, PLEASE, don't mention CPU overclocking with low profile cpu cooler. Forget cpu overclocking...main target is at least to make cpu work with proper temperatures and no throttling.
Reactions: loader963
loader963
665
571
Va
You mean you don’t find the “Can a Noctua L9i cool my 8700k OC’ed at 5.0Ghz?” topics funny? ;)
Some days I just want to be like, “Yes it will run flawlessly and should try it immediately!”
MarcParis
Apr 1, 2016
3,930
3,085
FRANCE
yeah you are right...sometimes we want to answer like that...especially on April's fool day..;);)
