Quick question:
Unfortunately my Strix 2080Ti OC is faulty, the fans have a mind of there own and do not respond to any of the default, manual or user defined fan curves and instead run at 100% all the time no matter what. They only stay silent if i use the dual bios feature of the GPU and select the silent bios but even then when the card has any sustained load the fans ramp up to 100% and stay there
I have been in contact with Asus support and followed their suggestions with no success, so they authorized an RMA through the retailer i got the GPU from. Unfortunately the process of this means I'll be left without a new GPU for 3 weeks or more, so as a last resort I'm contemplating removing the stock cooler and replacing with an Accelero Extreme III (same as i have on my 1080Ti with great success). Another option as a last resort would be (if the Accelero is not compatible), to just remove the fans and shroud and install 2 x Noctua fans controlled by a header on the motherboard.
Problem is I'm not sure if its compatible with the 2080Ti OC, anyone ?
Also what are your thoughts on the matter ? Even if it is compatible, should i just forget it and go ahead with the RMA ?
I have to decide by tomorrow morning, cause the GPU should be dropped off for the RMA tomorrow.
Decisions....
Decisions....
