Motherboard Asus B450-I VRMs and chipset temperature?
ZeblodS
Hi,
I have recently built an SFF computer using the following parts:
- SilverStone Sugo SG13
- Asus ROG Strix B450-I Gaming
- AMD Ryzen 2600X
- Sapphire RX 590 Nitro+ 8GB OC
- Corsair Vengeance 2x16GB DDR4 3200MHz
- Two Kingston A2000 250GB M.2 NVMe in Raid-0
- Enermax Liqmax III 120mm with BeQuiet SilentWings 3 Hi-Speed PWM and Noctua NT-H2
- Corsair TX750M modded with BeQuiet SilentWings 3 PWM and NTC 10k sensor glued on the secondary stage mosfets heatsink, both managed with the motherboard Q-Fan CHA fan.
What are the acceptable VRMs temperature?
smitty2k1
968
493
VRMs can handle high temperatures, and what you're seeing appears normal. As long as nothing starts thermal throttling you're fine.
paulesko
415
322
you should start worring about vrms when they reach 100ºC or so. They are usually rated to work at 125 maximum
