Motherboard Asus Pro H610T Thin ITX DDR4 SO-DIMM motherboard
DASBOOT
173
148
Almost all Thin ITX boards have an LVD panel connection to facilitate an all-in-one integration rather than use a separate monitor, the panel and its housing, are designed for a board of this type to be housed inside of the monitor's housing rather than on the outside using a VESA mount. The original concept was that OEM MFGs would design these monitor housings so the consumer could "build your own" AIO. I would suggest you, and any other SFF enthusiast read this info on thin ITX boards. THIN ITX OVERVIEW
