Motherboard ECS Thin Mini-ITX Motherboard takes direct 19V power
AlexTSG
562
537
www.youtube.com
Just saw news of this ECS H410 on Tom's Hardware. It's limited to 65W 10th Gen Intel CPUs, but you don't require a DC/ATX board in the system as you can attach a 19V AC Adapter directly to the motherboard (similar to how an Intel NUC board works). It also uses SO-DIMMs, reducing the profile further.
I use Thin Mini-ITX boards like this regularly for industrial PCs, but they're all typically using much older chipsets and CPUs. This is the first I've seen supporting a 10th Gen Intel CPU.
Reactions: scatterforce
