If you're in the market for a compact Intel Alder Lake integrated graphics build, then this might be for you.
Asus Pro H610T ITX DDR4 SO-DIMM Motherboard Hits Retail This Week | Tom's Hardware (tomshardware.com)
These are the type of boards I normally work on for industrial PC builds.
If you're wondering what a Thin ITX motherboard is, it's one that supports a direct 19V DC input, so there's no need for a PicoPSU or other DC/ATX type power supply here. You can connect a 19V power brick directly to the motherboard via the rear barrel connector, or an internal AC/DC PSU to the internal header.
There's no PCIe slot and only support for 65W processors, so this would be for integrated graphics builds only, unless you get creative with the M.2 slot and use an adapter in that to connect a discrete graphics card, instead of an SSD.
This would likely work well in a case like the 3.3L NFC Skyreach 4 Tiny or a J-HACK Pure.
