ASUS’s TUF sub-brand is generally known for a more industrial aesthetic and lower prices (and feature set) compared to the ROG family. With today’s cost to build a new PC skyrocketing, anything even slightly cheaper is welcome. ASUS has now launched the TUF Gaming B850I WiFi Neo Mini-ITX motherboard, based on AMD’s AM5 platform.
With the B850 chipset and AM5 socket the new board supports Ryzen 7000, 8000 and 9000 series CPUs, which will be powered by an 8 + 2 + 1 VRM loadout in this instance, with a capacity for 80A of spicy pixies. As is usual for the Mini-ITX form factor, a pair of DIMM slots feed the CPU, with up to 128GB of DDR5-8200 depending on the processor you install. On the expansion slot front, a PCIEx16 slot is present, running at Gen 5 speeds if a 8000 or 9000 series CPU is installed, or Gen 4 for one in the 8000 family.
A pair of SATA ports, as well as a pair of M.2 slots form the storage capability of the board – but as per TechPowerup:
Worth noting that ASUS labels...
Continue reading...
