Motherboard ASRock X370 Gaming-ITX/ac and AB350 Gaming-ITX/ac
Boil
1,253
1,094
"The X370 and B350 chipsets support 2x USB 3.1 (10Gb/s) ports and those two rear USB ports are colored for USB 3.1, so the spec sheet could be incorrect. We’ll follow up with ASRock to verify."
Definitely check into that USB 3.1 thing...!
CknSalad
This may sound like a silly question, but is there a major difference between the X370 and B350 for mini-itx? Spec-wise they seem the same pretty much. I am thinking of just getting the AsRock B350 for my Dan A4.
4,793
I can't find a difference for ITX other than the possibility of PCIe bifurcation support on X370.
Reactions: LukeD
6,074
5,007
It may just be a way to gauge interest, if the board itself is identical and all it needs is a different chip (X370 or B350) and a different SKU.
Or it might just be because they can scoop more margin from a higher priced model that basically has no extra research costs.
Boil
1,253
1,094
Also, if possible, check if either the B350 or X370 motherboards support ECC...?!?
4,793
I think it's this, people will get the X370 because surely it's better right?
I should have asked that too and forgot, I'll follow up once I get a reply from the first email.
Moravid
Do we know if the HDMI is ver 1.4 or 2.0? If it's the latter then I'll just grab Bristol Ridge APU to power my 4k monitor and upgrade once Raven Ridge arrives.
NFSxperts
112
53
I'll probably grab the B350 version as well since it looks like the cooling is the same and I don't need the extra features
kogepathic
23
32
Are there any photos of the bottom of the board?
Also is the WiFi card socketed?
From the photos published it seems like there might be a mini-PCIe x1 slot under the giant metal cover near the WiFi antennas. If so, that would be great news to later upgrade to 802.11ad.
4,793
The board does NOT have USB 3.1 (Gen 2). But the reason is apparently there are very strict limitations on trace length to use the USB 3.1 off the chipset and it wasn't feasible to implement on this board.
ASRock says that X370 has better overclocking potential, I believe mainly due to memory.
Bifurcation is maybe possible. But they're not going to test it, it's not supported, and if attempting it somehow damages the motherboard it's not their problem.
ECC is supported on both boards.
1.4b unfortunately.
Anyone got a release date yet?
Soon™
I don't have any.
I'm 99% sure it is. Almost always it's a socketed card underneath that metal cover because mini-PCIe and M.2 wireless cards are so plentiful it'd be dumb to order a custom one that's soldered to the motherboard or something.
BirdofPrey
Standards Guru
Sep 3, 2015
797
493
It seems kind of a shame to not support bifurcation on the X370 chipset since the ability to run dual graphics is that chipset's main feature.
4,793
Yeah, but why spend money validating a feature 0.01% of customers will use?
They didn't outright say it wouldn't work though...
Nintenrax
I must say I'm a little dissapointed in the recently announced Ryzen ITX-boards. The lack of USB 3.1 (and USB ports in general) on the Asrock board and the bad placement of the connectors and the non-Intel LAN chip on the Gigabyte board kinda put me of. Hopefully ASUS or MSI swoop in and bring the best of both worlds.
775
759
Yes, the limited number of USB ports is disappointing, but we're not sure that the differently colored ports (including Type-C) on the back are not USB 3.1 Gen2...we think the sales sheet was incorrect and are awaiting to see if there are corrections from ASRock.
Edit: didn't know ASRock got back and they are not Gen2 connections, a bit of a disappointment, indeed.
